We want to freeze the highlighted pane (filter strip, user input lane). This should be visible all the time, even when user scrolls bottom of the dashboard.
It is already working like you wish. Test for example Grafana
Upgrade your Grafana if it is not working for you.
Thank you @jangaraj for your prompt help, will update you at the earliest.
