8.1.2
Filter columns that stick when dashboard refreshes preferably per user
by applying a filter
- What happened?
filter is reset
filter to stick
I may be missing something obvious but on a table panel when applying a filter to column every time the dashboard refreshes the filter is lost. We have a dashboard that refresh’s every 5s making filters useless. I was expecting each user viewing the dashboard to be able to apply a filter that persists on that dashboard until they reset the filter view.
welcome to the
forum, @pr1malc0de
do you think you could try and replicate this on our public sandbox, https://play.grafana.org?
I have the same problem here with Grafana 8.2.1. When the panel refresh the filter clears. Also if we just resize the column it also clears the filter.
I don’t think that this should be normal behavior.
I don’t see any other option for the filters in the table panel configuration.
I was able to reproduce both issues with the sandbox.
certainly looks like there is a bug with the filter maintaining state. I’ll make an issue in the repo and link it here
I don’t see any issue for this problem in the Grafana repo. Has it been created yet ?
Thanks,
@jorisjean my apologies–I haven’t had a chance to make one yet.
Do you think you could create one and copy in your screencast?
You’re right I could have done it. Thanks for taking care of it.
