Table Panel not updating number of rows filtered
  • Versions Tested (Grafana v9.16 , 8.5.2)
    Table panel not updating the number of rows when a filter is applied in UI.
Want to show count of rows when a client side filter is applied through table panel filter
I am using Table panel to display data from MySQL database.
Using Column filter (Enables/disables field filters in table) button on panel configuration, table filtering is enabled.
Also the table panel has pagination enabled.
  • What happened?
When a user filter data using the column filter, th count of rows that appears at the bottom right is not getting updated with the count based on filter, rather shows the total count of rows read from panel query.
The count of rows should be updated with the count based on filter if a filter is active ?
    Attached dashboard JSON using a simple mysql.metrics table.
For example. The below table panel is having no filters and it shows 602 rows at the bottom.
The below screen , I am filtering 2 metrics. But the count still shows 602 entries.
Is there any way to show the number of rows present when user do a client side filtering ?
Any response from Grafana team? Its odd that going to last pagination page shows x-y of n where y is updated on filtered list but the count view still shows n
is there an update on this? I have a manager requesting a row count on a filtered table.
