Grafana v11.3.0 (not the enterprise version)
I am trying to display a totals column for each month
Using a table visualization and enabling a footer with total sum.
What happened?
The footer is not summing correctly, and in some columns it is just creating a string of all the values. (My values are numeric, not strings)
I expected correct sums.
