Table footer not appearing
I am trying to sum all number columns at table footer.
But some of them does not appear for me to choose. I tried not choose any but the behavior is the same.
The list of columns that appears:
Some columns thats should appear but it doesnt: L D0-1h, L D-1, L D-7.
Someone knows how to fix it?
Wonder if they are hiding since it is a long list of columns?
Can you type L or scroll down that list?
I guess those columns are strings a not a real numbers. Make sure your query returns numbers (integer, float) and not only a strings, which look like a numbers.
Thank you so much! It worked perfectly!
