8.5.9 Windows 11
I am trying to add a footer to count by row. -
I turned on the show footer option, which gives me an option to choose a reducer function. In this case COUNT. This then should give me an option to choose a FIELD so I can count the rows in that FIELD. -
What happened?
The FIELD drop down does not offer me any attributes to count the rows. -
I expected the drop down to give me an option to filter by a fields.
