Debian 11, Grafana 9.2.5 - What are you trying to achieve?
I want to groupby distinct count in the table. For each country code, I’d like to group by and show the number of instances (count).
I am looking for a table that has 2 columns: Country, Count
I’ve tried using Group By in transformations panel. But no “count” appears in the table. If I try to use “Calculate > Count”, nothing happens. -
My query is very simple{job="http-access"} | json -
No errors. -
I followed everything I could search on SO + this forum.
I also tried doing this natively in the query itself:
But, now the table appears to group by country, but it is not a “flat” table. It has a drop down selection menu like this:
The query is as follows:
count by(country) (rate({job="http-access"} | json [$__interval]))
I just want a very simple two column table with country and number of times it appears in the selected interval. Any help appreciated, spent way too much time on this, I feel like this is a simple thing to do and I am definitely missing core understanding of how Grafana works.
