Grafana v9.5.3 (916d9793aa) -
I am using Databricks clusters as data source. My query looks like this:
SELECT time_col, status, sum(count) AS count
FROM ,y_table
WHERE $__timeFilter(time_col)
GROUP BY time_col, status
ORDER BY time_col, status
I want to have a stacked bar chart. Each stack has the sum(count) of different status stacked on top of each other for a given value of time_col.
I thought what I need is the count column pivoted based on values in status column.
Example: if status column has two distinct value: status_1 and status_2; I want to have such a result:
| time_col | count_status_1 | count_status_2 |
I was thinking Grafana handles it. I had seen examples before. But I am not sure how they are done. I triedcolor by coloption fromBar ChartSetting side panel. -
What happened?
Group by, by itself does not do the trick. Using color by col also didn’t help. I see different status values, but they are all treated as a single column and with the same color without being able to stack them. -
No
