Grafana 9.0.2, Ubuntu 20.x.x and InfluxDB 1.8 -
Always showing the totals -
By making 4 seperate query’s and combining them in the Transformations tab -
What happened?
Somethimes the total value of two rows is not shown while there both visible and from the same table. -
Always showing a total value -
No errors to find what so ever only NaN errors which cannot be true
So the value Voorzijde totaal is a binary operation from Voorzijde PV 1 and 2.
Both values are collected in a seperate query but are limited to 1 for the last value.
Query C and D are seperate but come from the same InfluxDB series/table.
The values in the Explore screenshot differ from the one above since a refresh in between
Why is Voorzijde totaal empty / NaN but the values are showing in the query’s tab?
