Error=plugin xychart is already registered
I’m using Grafana version 11.1.4, and deploying and managing my grafana using provisioning files. I have recently started getting this error. Currently I’m not installing or managing any plugins manually. Could someone please help to fix this issue?
logger=migrator t=2024-08-30T10:25:19.101370134Z level=info msg=Unlocking database
logger=secrets t=2024-08-30T10:25:20.225103193Z level=info msg=Envelope encryption state enabled=true currentprovider=secretKey.v1
logger=plugin.angulardetectorsprovider.dynamic t=2024-08-30T10:25:20.63491394Z level=info msg=Restored cache from database duration=374.938786ms
logger=plugin.store t=2024-08-30T10:25:21.948521301Z level=info msg=Loading plugins...
logger=plugins.registration t=2024-08-30T10:25:21.977565826Z level=error msg=Could not register plugin pluginId=xychart error=plugin xychart is already registered
logger=plugins.initialization t=2024-08-30T10:25:21.977608377Z level=error msg=Could not initialize plugin pluginId=xychart error=plugin xychart is already registered
logger=local.finder t=2024-08-30T10:25:21.977674368Z level=warn msg=Skipping finding plugins as directory does not exist path=/usr/share/grafana/plugins-bundled
logger=plugin.store t=2024-08-30T10:25:21.977688968Z level=info msg=Plugins loaded count=54 duration=29.168858ms
logger=query_data t=2024-08-30T10:25:23.481504418Z level=info msg=Query Service initialization
logger=live.push_http t=2024-08-30T10:25:23.485012061Z level=info msg=Live Push Gateway initialization
logger=ngalert.notifier.alertmanager org=1 t=2024-08-30T10:25:24.987601108Z level=info msg=Applying new configuration to Alertmanager configHash=315ba12e3fc26aab1d0ded6978107415
logger=ngalert.notifier.alertmanager org=1 t=2024-08-30T10:25:26.864554691Z level=info msg=Applying new configuration to Alertmanager configHash=d2c56faca6af2a5772ff4253222f7386
logger=ngalert.state.manager t=2024-08-30T10:25:28.55316381Z level=info msg=Running in alternative execution of Error/NoData mode
what does your plugin provision yaml file look like please post
I don’t have a plugin provisioning file. All the plugins which I have right now, are core plugins which are getting installed by default.
Update on Solution: Figured out the issue!
It had nothing to do with xycharts, even though it shows up on logger. What it was not able to do was provision the alerting.
I was not getting this particular log on my console when my provisioning build was failing. "logger=provisioning.alerting t=2024-09-02T15:50:19.690172581Z level=info msg=“finished to provision alerting”. I found out that I was missing “notification policies” definition on my provisioning, even though I had alerting and contact point yaml file definitions. After adding notification policies.yaml file into my provisioning, the deployment was successful.
