Grafana OSS 9.0.3 -
I wanna install XY Chart Plugin -
I am installing it via Grafana plugin, however, there is no “install button” -
What happened?
No install button for XY chart, it just say that it is already included in Grafana.
Easy installation.
it’s say it’s already included, did you verify that ?
i think this is native plugin in 9.0 + no install needed. Can you find it in your panel list ?
Yeah. That’s actually weird, it says it is alreadt installed but there is no on my panel list.
It is not a prod panel. Only alpha/beta so try enable enable_alpha config to see non prod panel types.
Never knew about this. Thanks for the info!
