Error after update plugin and restart
  • v8.1.2 (103f8fa094), Ubuntu Linux 20.04.2
I wanted to make an update to zabbix grafana plugin
I am looking on the internet, I did not find anything … I turned off the plugin, restarted the grafan
  • What happened?
"Error
Post “http://192.168.3.3/zabbix/api_jsonrpc.php”: net/http: invalid header field name “”
that the updates are going to work?
"Error
I fixed this by removing the custom HTTP headers in the edit data source page
Thank you so much for writing the solution! I had the same error, when trying to use alerts with influxdb (normal queries in panels worked). This was also caused by an empty custom http header that somehow appeared in the datasource.
