Error conection data source zabbix
    Grafana V9 Rocky Linux V 9.1
    Create a zabbix database
    I install the zabbix plugin in same host as zabbix and nginx, and configure it
  • What happened?
    When I try to validate the configuration, I receive this error message: request failed, status: 404 Not Found
    I expect it to connect
    URL http://10.100.100.50/zabbix/api_jsonrpc.php
    Access Browser
Log in Grafana UI: request failed, status: 404 Not Found
Log in Nginx: [error] 2060#2060: *981 FastCGI sent in stderr: “Primary script unknoum” while reading response header from upstream, client:10.100.100.50, server: 10.100.100.50, request: “POST /zabbix/api_jsonrpc.php HTTP/1.1”, upstream: “fastcgi:/unix:run/php-fm/zabbix.sock:”, host: “10.100.100.50”
Yes
