Zabbix Grafana Integration request failed, status: 404 Not Found
  • What Grafana version and what operating system are you using? Grafana 8.2.4 Ubuntu 20.0.4
  • What are you trying to achieve? Integration between Zabbix and Grafana via plugin.
  • How are you trying to achieve it? Downloaded plugin to Grafana, issue occurs when trying to add Zabbix as a data source.
  • What happened? request failed, status: 404 Not Found
  • What did you expect to happen? Integration between Zabbix and Grafana
  • Can you copy/paste the configuration(s) that you are having problems with? Yes via screenshots if requested.
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. request failed, status: 404 Not Found
    I am looking to integrate Zabbix with Grafana. For this project I spun up a new Ubuntu 20.0.4 VM and followed this walkthrough exactly for the Zabbix install: Zabbix Monitoring: The Ultimate Guide and this install exactly for the Grafana install: https://linuxways.net/ubuntu/how-to-…-ubuntu-20-04/
I can successfully install the Zabbix for Grafana plugin, when I go to select Zabbix as a data source I follow the plugin directions exactly.
I have also tried other solutions found online to change login “Access” from Server to Browser, and to remove /zabbix/ in the URL. I am also replacing ‘hostname’ in the URL with the IP of the VM running both Grafana and Zabbox. None of these solutions work I always receive
I am able to access both Grafana and Zabbix via HTTP and at localhost:80 shows the Apache default index page. Looking for assistance I am out of ideas.
Did you try the solution mentioned here
If yes, please share with us a screenshot for your current configuration.
Good Luck
Yes I tried this with no luck. Screenshot of my configuration is below:
in regards to the URL i have tried
http://localhost/zabbix/api_jsconrpc.php
http://localhost/api_jsconrpc.php
https://localhost/zabbix/api_jsconrpc.php
http://127.0.0.1/zabbix/api_jsconrpc.php
http://127.0.0.1/api_jsconrpc.php
https://127.0.0.1/zabbix/api_jsconrpc.php
http://10.200.10.19/zabbix/api_jsconrpc.php
http://10.200.10.19/api_jsconrpc.php
https://10.200.10.19/zabbix/api_jsconrpc.php
Deleted the VM this morning and did a fresh install of Zabbix and Grafana, issue persists.
Can you curl to any of the addresses ?
curl https://127.0.0.1/zabbix/api_jsonrpc.php
Also do you have firewall / selinux enabled ?
Good Luck
Make sure that you use apache to connect with zabbix. Because I have installed nginx, so my 80 port is used for nginx, and it keeps me generating error message. You should specify the apache’s port if you have also installled nginx
Try without “/zabbix/”
Hello from Brazil
Tks Luiz, i really apreciated your tip dude.
Thanks for help. I had similar problem in zabbix-grafana when add data source. I deleted /zabbix and my problem resolved.
Valeeeeuuu, resolveu mesmo !! tmj
“404 Not Found” on Zabbix integration is always the following reasoning:
The server answers, then it’s not the IP communication and a “404” means that the path to the resource “api_jsconrpc.php” doesn’t exists, then you need to check the path.
Zabbix is commonly installed on the root “/” or the “/zabbix” path. Then if one doesn’t work, try the another one.
I don’t think that all this options answered the “404 Not Found” right?
