Error 500 when update dashboard
Errors appear in syslog after configuring zabbix + grafana:
> level=error msg="Request Completed" method=POST path=/api/ds/query status=500 remote_addr=10.26.35.226 time_ms=93 duration=93.583004ms size=116 referer="http://10.26.34.7:3000/d/8H2UXzFVk/servers-health?editPanel=24&orgId=1&refresh=5m" handler=/api/ds/query
> level=error msg="Internal server error" error="[plugin.downstreamError] failed to query data: Failed to query data: rpc error: code = Canceled desc = context canceled" remote_addr=10.26.35.226 traceID=
At the same time, all metrics work without problems. How can I get rid of this error so as not to overload the logs?
@zatowarlock Did you get the cause of error?
Hello, i have similar problem. It was started afrer update grafana from 8.6 to 9.3 version and plugin zabbix.
Hi @vdobychkin and others,
If this is related to the Zabbix Plugin, please report it to the GitHub page as Zabbix is a Community-based plugin.
Once you create the GitHub issue, then paste it here so that other users can also be aware of it and get easier to track.
Thanks
Update to this post thread:
Link to the GitHub issue:
