How do I set it up so that each panel in the dashboard has its own timeline. I can’t get it to run. all panels are always the same. this is driving me insane ![]()
Hi @petapan,
Thanks for opening this post.
Can you explain your use case in a bit more detail?
To me, it sounds like you need Rows to separate several panels from each other.
Hi @petapan,
Different time ranges for each panel can be achieved by specifying “Relative time” in Query Options like on picture:
Result:
Note: All 5 panels show same metric but in different time ranges. By changing global dashboard time (in upper right corner) only time range of 1st panel would change.
Hope this helps. ![]()
Best regards,
ldrascic
