As depicted above I need to change the time range from 6 hours to 5mins, but once I have changed it, other panels time range changes in that dashboard as well. Is there anything I can do to change the time range only for one widget? , there were some similar questions and answers but most of them are outdated and related to influxDB , It would be great if someone can help me with this issue, Thank
Hi @chamathjayasekara99,
You can set different time ranges for any data source by using “Query options” → “Relative time”. Please check answer on next link:
Hope this helps.
Best regards,
ldrascic
Thank you so much ! for your response, Also one question, Is it possible to remove the time picker from each panel ?, can it be done changing the json format of the query ?
Why you want to remove it? What issue are you trying to solve?
You can hide time picker in Dashboard settings (cog icon) -> General.
Best regards,
ldrascic
