Can we create time filter for each/specific panel in dashboard?
    10.0.3
    creating time filter for a specific panel
  • What happened?
Yes you can. What is your datasource
Azure data explorer
You will some examples for using time filter
AzureActivity
| where $__timeFilter()
| project TimeGenerated, ResourceGroup, Category, OperationName, ActivityStatus, Caller
| order by TimeGenerated desc
My requirement is to create a dropdown tike filter for a specific panel
You can create that using dashboard variables. What would be the datasource of that drop down
Dropdown should have options like 5 min ago, 15 min ago, 30 min ago, 1 hour ago …
And for this i am thinking to have csv data source. Is there any best alternative for this ??
Use grafana’s built in time picker
Built in time picker will affect all the panels. I need to have time picker for specific panel so it will not disturb other panels on changing the time
As @yosiasz suggested, you can use dashboard variables and use them in your data source queries to retrieve data.
To select a time range, you can use the Variable panel, which has minimized and button views:
Or you can incorporate Apache ECharts panels with select elements and toolbox:
Not necessarily, if you dont use the global variables values of _from _to
I wanted this type of time filter dropdown at the panel level not at the dashboard level
I am able to achieve this by variable panel
@ahareesh Great! Can you share a screenshot to share with the community?
I have achieved this in 2 ways.
  1. using dashboard variables
  2. using variable panel .
