Writing to get your help. Please take a look. Thank you in advance.
Below is description:
- Main Report displays current count of units as follow:
$var_currentCount
2. Variablefor main report is $var_currentCount is SELECT units FROM table where entityin ('$var_entities') 3. Main Report is on dashboard1that is filtered by selection of entityfrom dropdown that is on a top of dashboard1I need to create view details report that will be opened from link that is on Main Report. View details report need to be filtered by '$var_entities' that is selected on a dropdown on dashboard1.So, practically, I need to pass current entity selection in dropdown on dashboard1 to drilldown report.I’m wondering if it is possible. Thank you-
What Grafana version and what operating system are you using? – Grafana 8, Linux
Whatare you trying to achieve? – I need to pass current entity selection in dropdown on dashboard1 to drilldown report.I’m wondering if it is possible.
Howare you trying to achieve it? – tried all sorts of links but does not work
What happened? – did not work
What did you expect to happen? – view details report to open filtered by entity selected on dashboard where main report is located
Can you copy/paste the configuration(s) that you are having problems with? – NA
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactlywhat they were. – details view report opens not filtered
Did you follow any online instructions? If so, what is the URL? --NA
