Grafana OpenShift Operator version 5.9.2 running in OpenShift 4.12.45
The grafana-a-deployment Deployment needs the environment variables NO_PROXY and HTTPS_PROXY to work in our environment. I can set these environment variables manually which works for a day or so until the Operator re-configures the Deployment and deletes these environment variables.
Is there a way to configure the Grafana Operator to configure the grafana-a-deployment Deployment to use NO_PROXY and HTTPS_PROXY?
There is a page in the Grafana Operator documentation that shows how to configure the grafana-a Custom Resource to pull secrets as environment variables into grafana-a-deployment, and you can adapt this for defining the variables directly in the yaml like this:
spec:
deployment:
spec:
template:
spec:
containers:
- env:
- name: NO_PROXY
value: <URLs>
- name: HTTPS_PROXY
value: <URL>
After making this update to the YAML configuration for grafana-a, the Deployment grafana-a-deployment will automatically deploy a new Pod with the specified environment variables.
