./agent-linux-amd64 --version
agent, version v0.24.1 (branch: HEAD, revision: 35015aa4)
build user: root@4500bb0cda4b
build date: 2022-04-14T15:27:31Z
go version: go1.17.6
platform: linux/amd64 -
Connect machine behind firewall to push metrics to Grafana Cloud -
Run the agent configured on the local machine -
What happened?
It can’t connect to the internet because its requires a web proxy -
Trying to follow (Grafana Agent | Grafana Cloud documentation) to install agent.
The agent config for metrics (see metrics_config | Grafana Agent documentation) does not have a proxy_url option like Promtail does (see grafana .com/docs/loki/latest/clients/promtail/configuration/#clients_)
There are no command line options that allow me to configure a proxy.
It looks like go should support the environment variable https_proxy and use that transparently. But that hasn’t worked either.
ts=2022-05-03T04:56:35.229954187Z caller=dedupe.go:112 agent=prometheus instance=XXX component=remote level=warn remote_name=XX url=https://prometheus-prod-10-prod-us-central-0.grafana.net/api/prom/push msg="Failed to send batch, retrying" err="Post \"https://prometheus-prod-10-prod-us-central-0.grafana.net/api/prom/push\": context deadline exceeded"
What are my alternatives?
