Does Azure Managed Grafana support setting disable_sanitize_html to true?
Does Azure Managed Grafana support setting disable_sanitize_html to true, in order to in a Text Panel?
I am using 9.5.13 version of Azure Managed Grafana currently it is not supporting the script on the text panel.
I would ask your Azure support, because they know if it is supported/allowed or not.
For example Grafana Cloud doesn’t allow to configure it due to security reason. Maybe Azure is less restrictive on security.
Can you please suggest any other way to use html and javascript on a Grafana panel?
