Disabling Sanitize HTML - Text panel issue after upgrade
Hi!
Upon the upgrade to 6.0, we’re having an issue - by default Grafana now applies sanatize_html. We have one line of unsanatized html code in our project (it’s to hide a column that is being used for sorting/ordering).
Since we’re using Grafana Cloud, we’re unable to access the config file and disable sanatize_html.
Is anyone aware of a workaround?
Is there a way to still use a version before 6.0?
Here’s the single line of code that is being affected:
.table-panel-table td:nth-of-type(1), .table-panel-table th:nth-of-type(1) { display: none; }
Hi Ballast, did you find a solution for this?
Hi @ballast & @mfleury
Grafana Cloud environments do not allow setting disable_sanitize_html to true, due to security concerns:
This is something you can choose to edit with a self-managed Grafana environment if the risk is tolerable.
If the original goal was to hide a column that was used for sorting/ordering, you should be able to use a field override or transformation.
For example:
