How to set disable_sanitize_html to true
i have a problem that i use grafana inside docker, i want to set disable_sanitize_html to true,
so that i can use text panel html mode, please let me know to type the grafana-cli in the powershell, thanks!~
You need to change this in the Grafana configuration file:
[panels]
disable_sanitize_html = true
thanks marcus, but where to find this configuration file? my grafana is a docker container.
Although the thread is a few month old, I’d like to share the solution:
In the settings of the docker container you need to add an environment variable representing the entry you want to change (GF_PANELS_DISABLE_SANITIZE_HTML) and set it to TRUE.
grafik
After restartng the container the HTML tag is displayed properly.
thanks, it worked here!
