Docker -
Have the Docker container update without it resetting to default with no data -
updating the docker container -
What happened?
Everytime the container for Grafana updates it seems to reset it self, meaning I have to set the password and setup my dashboards again -
Not have to resetup the system from default each time there is an update -
#!/bin/bash
workname=grafana
workdir=/docker/data/$workname
workpackage=grafana/grafana
extport=3000
intport=3000
docker run -d -h $workname
–restart=always
–name $workname
-v $workdir/config:/config
-p $extport:$intport
-e TZ=Australia/Queensland
-e PGID=$PGID -e PUID=$PUID
$workpackage
that is the Docker run command I am using
That is the report I have from Watch tower this morning after updating the container and when I go to access it, its fully reset and all data is missing
