Grafana Docker and data persistence
Hello all,
I am trying to get my Grafana docker container to persist data. I’ve configured the container to run as root to rule out any user account related issues. I’m not sure what I’m doing wrong but I can’t get the data to persist.
I can remove panels from the default Home dashboard. If I create a custom dashboard everything seems to be OK but as soon as I log out and re-login (to the default admin account) it is as if I’m logging in for the first time.
Here’s my docker-compose file
  grafana:
    image: grafana/grafana:latest
    user: root
    restart: unless-stopped
    container_name: grafana
    volumes:
       - $PWD/data/grafana:/var/lib/grafana
       - $PWD/conf/grafana:/etc/grafana
       - $PWD/logs/grafana:/var/log/grafana
       - $PWD/data/grafana/provisioning:/etc/grafana/provisioning
    environment:
      - "GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource,grafana-piechart-panel"
    networks:
      - backend
What am I doing wrong? Initially, the container complained about not finding directories (dashboard, datasources and notifiers) within the provisioning directory which I expected it to create under /etc/grafana so to overcome that I added the last binding and manually created these directories under the provisioning directory.
Thank you in advance
Have you made the data directories first? Are the permissions on them correct? Personally i hate using $PWD and always set a full path. I like using /docker_data as it makes it obvious to anyone after me what it is.
Try this…
version: '3'
services:
  grafana:
    depends_on:
      - influxdb
    ports:
      - 3000:3000
    volumes:
      - /docker_data/grafana_data:/var/lib/grafana
      - /docker_data/certs:/certs
    env_file:
      - /docker_data/grafana_conf/config.monitoring
    environment:
      - HTTP_USER="{{ grafana_user }}"
      - HTTP_PASS="{{ grafana_passwd }}"
      - INFLUXDB_HOST=influxdb
      - INFLUXDB_PORT=8086
      - INFLUXDB_NAME="{{ db_name }}"
      - INFLUXDB_USER="{{ influxdb_user }}"
      - INFLUXDB_PASS="{{ influxdb_passwd }}"
    restart: always
  prometheus:
    image: prom/prometheus
    container_name: prometheus
    volumes:
      - /docker_data/prometheus_conf:/etc/prometheus/
      - /docker_data/prometheus_data:/prometheus
    command:
      - '--config.file=/etc/prometheus/prometheus.yml'
      - '--storage.tsdb.path=/prometheus'
      - '--web.console.libraries=/usr/share/prometheus/console_libraries'
      - '--web.console.templates=/usr/share/prometheus/consoles'
    ports:
      - 9090:9090
    links:
      - grafana
      - influxdb
    restart: always
  influxdb:
    image: docker.io/influxdb
    container_name: influxdb
    ports:
      - "8086:8086"
    volumes:
      - /docker_data/influxdb_data:/var/lib/influxdb
    env_file:
      - '/docker_data/influxdb_conf/env.influxdb'
    restart: always
That should give you a stack.
I use Ansible for all the lifting -
docker-install.yml
      connection: localhost
      hosts: localhost
      tasks:
          args:
            chdir: /home/
          command: "curl -fsSL get.docker.com -o get-docker.sh"
          name: "Download docker script"
          name: "run docker script"
          script: /home/get-docker.sh
          service:
            state: started
          apt:
            state: present
          register: results
          debug:
            var: results
          command: "pip install docker-compose"
          name: "install docker-compose"
          name: "include vars file"
          include_vars: docker_install.var.yml
          name: "create docker data folders"
          file:
            path: "{{ item }}"
            state: directory
            mode: 0777
          with_items:
              - /docker_data/portainer_data
              - /docker_data/chronograf_data
          name: "create docker config folders"
          file:
            path: "{{ item }}"
            state: directory
            mode: 0775
          with_items:
              - /docker_data/influxdb_conf
          name: "create telegraf.conf from template values"
          template:
            dest: /docker_data/telegraf_conf/telegraf.conf
            src: telegraf.conf.jk2
          name: "create telegraf.conf outputs from template values"
          template:
            dest: /docker_data/telegraf_conf/telegraf.d/telegraf.outputs.conf
            src: telegraf.outputs.conf.j2
          name: "create telegraf.conf inputs from template values"
          template:
            dest: /docker_data/telegraf_conf/telegraf.d/telegraf.inputs.conf
            src: telegraf.inputs.jk2
          file:
            mode: 420
            path: /docker_data/telegraf_conf/telegraf.conf
          name: "change file permission"
          name: "create grafanacfg.output file with values"
          template:
            dest: /docker_data/grafana_conf/grafanacfg.output
            src: grafanacfg.input.jk2
          name: "create influx env file"
          template:
            dest: /docker_data/influxdb_conf/env.influxdb
            src: env.influxdb.j2
          name: "create grafana config file"
          template:
            dest: /docker_data/grafana_conf/config.monitoring
            src: config.monitoring.j2
          name: "create docker-compose.yml from template"
          template:
            dest: /docker_data/docker-compose.yml
            src: docker-compose.yml.j2
          name: "create docker-compose .env from template"
          template:
            dest: /docker_data/.env
            src: docker-compose.env.j2
          args:
            chdir: /docker_data/
          command: "docker-compose build"
          args:
          command: "docker-compose up -d"
          name: "Wait 300 seconds for port 3000 to become open on the host, don't start checking for 10 seconds"
          wait_for:
            delay: 10
            port: 3000
          name: "Set Grafana admin password"
          command: docker exec -t grafana bash -c  'grafana-cli --homepath /usr/share/grafana admin reset-admin-password "{{ grafana_passwd }}"'
          name: "check if grafana can be accessed"
          command: "curl -s http://grafana.staged-by-discourse.com/api/org -u {{ grafana_user }}:{{ grafana_passwd }}"
          name: "create datasoure in grafana"
          command: "curl -L --header 'Content-Type: application/json' --header 'Accept: application/json' -d@//docker_data/grafana_conf/grafanacfg.output http://grafana.staged-by-discourse.com/api/datasources -u {{ grafana_user }}:{{ grafana_passwd }}"
          name: "create TelegrafHost dashboard in grafana using jsonfile"
          command: "curl -L --header 'Content-Type: application/json' --header 'Accept: application/json' -d@/home/Configfiles/dashboards/TelegrafHostMetrics.json  http://grafana.staged-by-discourse.com/api/dashboards/db -u {{ grafana_user }}:{{ grafana_passwd }}"
          name: "create DockerMetrics dashboard in grafana using jsonfile"
          command: "curl --header 'Content-Type: application/json' --header 'Accept: application/json' -d@/home/Configfiles/dashboards/DockerMetricsperContainer.json  http://grafana.staged-by-discourse.com/api/dashboards/db -u {{ grafana_user }}:{{ grafana_passwd }}"
          name: "create JVM dashboard in grafana using jsonfile"
          command: "curl --header 'Content-Type: application/json' --header 'Accept: application/json' -d@/home/Configfiles/dashboards/jvm-metrics-jolokia-2_rev1.json  http://grafana.staged-by-discourse.com/api/dashboards/db -u {{ grafana_user }}:{{ grafana_passwd }}"
docker-install.var.yml (example this wont work!)
grafana_user: !vault |
        $ANSIBLE_VAULT;1.1;AES256
grafana_passwd: !vault |
influxdb_admin_user: !vault |
influxdb_admin_passwd: !vault |
influxdb_user: !vault |
influxdb_passwd: !vault |
I suggest you use ansible-vault to not save passwords in plain text.
This should give you a good start, there are some files you will need to create, they are mainly your current config files saved as .jk2 or j2 (where I forgot the k). The dashborads I auto deploy can be removed or you can go to the Grafana page for them and download the yml.
Thank you very much for your help.
Since posting, I noticed that I am able to create and save dashboards etc. What I cannot do is reset the admin password (it keeps prompting me to change it every time" I also cannot seem to be able to edit the main “home” dashboard.
I thought it had something to do with Grafana being behind Traefik so I tested a standalone container with port 3000 exposed on http and found that it did the same thing so I know for sure it’s not Traefik.
Any ideas?
@tam481
I have the same problem. How did you solve it?
To do so:
  1. Stop and remove the grafana docker container
  2. Remove the grafana volumes
  3. Adjust below environment setting, for grafana container:
      GF_SECURITY_ADMIN_USER
  1. Re-create again the grafana docker container
Hey! For me, I had Grafana listening to Prometheus in a docker container. Although I created a volume for Grafana, I did not create a volume for Prometheus. Since Prometheus’ data was reset every time, Grafana also lost all the data as a result. Simply adding a volume to persist Prometheus data fixed the issue for me, as detailed here: persistence - How to persist data in Prometheus running in a Docker container? - Stack Overflow
