Docker container delete all my dashboards
I have a Grafana server configured in Docker this way:
  grafana:
    image: grafana/grafana
    container_name: grafana
    restart: always
    ports:
      - 3000:3000
    links:
      - influxdb
Every time I upgrade the image [docker-compose pull] y lost all my dashboards. My InfluxDB is in the DB, but I need to create the dashboards quieris again.
How could I keep my dashboard everytime I upgrade the container?
Thanks for your help.
Thanks!
I configured this way:
 grafana:
    restart: always
    volumes:
      - $PWD/docker_data/grafana/data:/var/lib/grafana
      - $PWD/docker_data/grafana/config:/etc/grafana
    ports:
      - 3000:3000
    links:
      - influxdb
The problem now is permisions, this is the grafana container log:
GF_PATHS_CONFIG='/etc/grafana/grafana.ini' is not readable.,
GF_PATHS_DATA='/var/lib/grafana' is not writable.,
You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migration-from-a-previous-version-of-the-docker-container-to-5-1-or-later,
mkdir: can't create directory '/var/lib/grafana/plugins': Permission denied,
This is the user permissions on the host:
$ ls -lh docker_data/grafana/
total 8,0K
drwxr-xr-x 2 root root 4,0K feb 14 12:24 config
drwxr-xr-x 2 root root 4,0K feb 14 12:24 data
Anyone running persistant data in docker?
Doc is your very good friend. You may save time if you read whole Grafana docker doc: https://grafana.com/docs/grafana/latest/installation/configure-docker/#run-grafana-container-using-bind-mounts
Thanks for the link.
I read all the page, but it doesn’t work.
I try:
  • Use -user xxxx (my user ID)
  • chown -R 104:104 directory
  • chown -R 472:472 directory
But nothing.
I will really appreciate your help.
Best regards.
