i’m testing grafana on a pi via docker, and want to login the webpage with username admin and password admin. But it gives an error unknown username or password. Has the default username been changed?
I have used this repository : grafana/grafana
can you please show us your docker compose or the command you run?
Yeah sure :
docker run -d
–name=grafana
-p 9003:3000
–restart=always
grafana/grafana
what do you see when you do docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
da13c7f77f0c grafana/grafana “/run.sh” 5 seconds ago Up 4 seconds 0.0.0.0:9003->3000/tcp grafana
Strange thing is last week I also installed this for testing and then it worked. So maybe a “bug” in the new version?
Hello, same situation here but installing on a raspberrypi. Just a few days ago everything was fine. Now, after reinstalling everything I’m struggling with this. I found this in the log every time I try to login with the default admin account:
logger=plugin.loader t=2023-08-24T20:22:25.738434805+02:00 level=warn msg=“Plugin missing module.js” pluginID=input warning=“Missing module.js, If you loaded this plugin from git, make sure to compile it.”
Maybe grafana/grafana#27924 strikes again??
just ran the same command using podman and it all looks good on my side
Looks like more people are having a problem with this. Good luck with trouble shooting.
Hi, is there any update on this issue?
