Default admin password can't login
v6.6.2
I am using the default admin password (admin)
However, I get a 500 (Internal Server Error)
and if i enter input another password, I get a 401 (Unauthorized).
  •  POST http://[url]/login 401 (Unauthorized)
  •  {message: "Invalid username or password"}
log is empty.
Yesterday I kept getting an error, and I was logged in by accident,
but today I can’t log in.
when enter another password
Can you look in Grafana’s server logs?
If you installed Grafana using Docker, you can use docker logs <container ID>.
If you can ssh to the grafana server, just do this
grafana-cli admin reset-admin-password new_passwd
I restarted…
After restarting, I am logged in as admin/admin again.
I think this is a bug.
There are quite a few bugs in Grapana…
thanks! i will check this later!
Docker right
That’s why the log was not visible.
