Hello Forum,
Am completely new to Grafana and can not figure out how to display sensor data on a graph in Grafana Cloud.
Have an embedded IoT device that measures voltage at a constant sampling rate (10ms interval), the MCU outputs a CSV file. The CSV does not contain any timestamps, just voltage values like that:
This is best practice to reduce file size (very important aspect in IoT) and as sampling rate is constant, this should not have any drawbacks.
My problem is that i can not find a way to display the contents of my CSV file as a graph or time series within Grafana. Is there any way i could tell Grafana what was the sampling rate and let Grafana draw the graph based on that info?
