I have this csv file:
host timestamp value
server1 1643135400000 5
server1 1643135500000 6
server2 1643135400000 19
server2 1643135500000. 20
I am trying to use csv plugin to creat a simple time series chart. I have done:
- create a data source from csv (done)
- create a panel and I picked timestamp and value, I cannot see the time series chart.
- I then used transformation to convert the epoch time to regular time, I still dont see that chart. It is empty
I need to be able create a time series chart for each host. The chart needs to have different time series data for each host.
How do I do this using grafana csv plugin.
