Hello!
I can’t figure out how to load a * .CSV or * .JSON file into Grafana and create a dashboard with data from one
Hello!
You need to use one of the plugin supporting those format , helpful ones :
CSV : CSV plugin for Grafana | Grafana Labs
JSON : JSON plugin for Grafana | Grafana Labs
Hope it helps.
Good Luck
Thank you for your answer, but I installed CSV plugin and I didn’t understand how open data on diagrams. Are instruction about it, may be?
It depends on your data types, can you see your data in a table format ?
Good Luxk
There’s no “CSV panel”. The screenshot is using the Table visualization to display the CSV data from the plugin.
