Grafana Cloud -
Delete Dashboards provisioned by GrafanaCloud -
Login to GrafanaCloud β navigate to dashboards β select Dashboard under GrafanaCloud folder and delete -
What happened?
Got the below error
provisioned dashboard cannot be deleted -
Successfully Deleted -
No Configurations used, Its provisioned automatically by the cloud. -
checked the internet, all has solution for hosted Grafana not the Grafana Cloud
Why can't I delete provisioned dashboard from UI?
Cant delete provisioned dashboard?
[SOLVED] How can I delete a provisioned dashboard?
I would say thatβs expected. You are using Grafana Cloud and those dashboards are for you, so you will know for example for what you are charged (e.g. metrics, logs, traces, β¦).
Yes, I agree with you. We are managing this dashboard using IaC, so we imported all provisioned dashboards based on our folder structure. This provisioned dashboard is already replicated in another folder, so it is not required. Is there any way to remove it?
IMHO not. Your imported dashboards have different UIDs, so they donβt know which dashboards should be updated when they will need to update some GrafanaCloud dashboards from time to time. Ask you Grafana Cloud support.
