v10.2.3
use plugin “data Manipulation” v3.6.0 with postgresql database -
insert data into table with input element
- What happened?
error message when click submit button when “Update Request Payload” function
insert value with element’s value (work fine with constant number value )
- Can you copy/paste the configuration(s) that you are having problems with?
my element for input value
after enter value and click on button “validation” ,this message error appears if i use ${payload.new_value} in my query as its explained in video !!
