Hello
I am trying to write a row in my postgreSQL database from Grafana with “business forms plugin” but there is no simple example explained
What Grafana version and what operating system are you using? 10 / 11
What are you trying to achieve? I want to write a row in PostGreSQL from grafana
How are you trying to achieve it? With the business forms plugin, I want to declare :
- The line
- The start Time
- The end time
- the status of the line for this time (open/close/maintenance…)
and write them in my PostgreSQL database
Problem
It is not writing in the SQL database the 4/5 parameters I wanted
- Can you copy/paste the configuration(s) that you are having problems with?
- my json panel code :
"datasource": {
"type": "grafana-postgresql-datasource",
"uid": "ddonkd2fx7h8ga"
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 8
"id": 7,
"options": {
"layout": {
"variant": "single",
"padding": 10,
"orientation": "horizontal",
"sectionVariant": "default"
"elementValueChanged": "let elements = context.panel.elements;\r\n\r\n// Trouver les éléments 'Debut' et 'Fin'\r\nconst Debut = context.panel.elements.find(\r\n (element) => element.id === \"Start\"\r\n);\r\nconst Fin = context.panel.elements.find(\r\n (element) => element.id === \"End\"\r\n);\r\n//const Ligne = context.panel.elements.find(\r\n// (element) => element.id === \"Line\"\r\n//);\r\n// Vérifiez si 'Debut' et 'Fin' ont des valeurs\r\nconst isFormValid = Debut && Debut.value && Fin && Fin.value;\r\n\r\n// Activer ou désactiver le bouton de soumission en fonction de la validité du formulaire\r\nif (isFormValid) {\r\n context.panel.enableSubmit();\r\n} else {\r\n context.panel.disableSubmit();\r\n}\r\n",
"sync": true,
"initial": {
"method": "datasource",
"contentType": "application/json",
"code": "console.log(context.panel.data, context.panel.response, context.panel.initial, context.panel.elements);\n\nreturn;\n\n/**\n * Data Source\n * Requires form elements to be defined\n */\nconst dataQuery = context.utils.toDataQueryResponse(context.panel.response);\nconsole.log(dataQuery);",
"getPayload": "return {}",
"payload": {},
"highlight": false,
"highlightColor": "red",
"datasource": "Postgresql"
"updateEnabled": "manual",
"update": {
"code": "if (context.panel.response) {\n context.grafana.notifySuccess(['Update', 'Values updated successfully.']);\n context.grafana.locationService.reload();\n} else {\n context.grafana.notifyError(['Update', 'An error occurred updating values.']);\n}",
"payloadMode": "custom",
"getPayload": "const payload = {};\n\ncontext.panel.elements.forEach((element) => {\n if (!element.value) {\n return;\n }\n\n payload[element.id] = element.value;\n})\n\n// Créer la requête SQL brute en utilisant un template string\nconst sqlQuery = `\n INSERT INTO \"DATA_SCHEMA\".\"LINE\" (\"id\", \"LINE\", \"start_time\", \"end_time\", \"planifie\")\n VALUES ('${payload.id}', '${payload.Ligne}', '${payload.Start}', '${payload.End}', '${payload.planification}');\n`;\n\n// Retourner l'objet avec la requête SQL brute\nreturn { rawsql: sqlQuery };\n\n\n\n\n",
"payload": {
"editorMode": "code",
"format": "table",
"rawQuery": true,
"rawSql": "INSERT INTO \"DATA_SCHEMA\".\"LINE\" (\"id\", \"LINE\", \"start_time\", \"end_time\", \"planifie\")\r\n VALUES ('${payload.id}', '${payload.Ligne}', '${payload.Start}', '${payload.End}', '${payload.planification}');\r\n",
"refId": "A",
"sql": {
"columns": [
"parameters": [],
"type": "function"
"groupBy": [
"property": {
"type": "string"
"type": "groupBy"
"limit": 50
"confirm": true,
"confirmModal": {
"title": "Confirm update request",
"elementDisplayMode": "all",
"body": "Confirmation",
"columns": {
"include": [
"name",
"oldValue",
"newValue"
"name": "Label",
"oldValue": "Old Value",
"newValue": "New Value"
"confirm": "Confirm",
"cancel": "Cancel"
"buttonGroup": {
"orientation": "center",
"size": "md"
"submit": {
"variant": "primary",
"foregroundColor": "yellow",
"backgroundColor": "purple",
"icon": "cloud-upload",
"text": "Submit"
"reset": {
"variant": "hidden",
"icon": "process",
"text": "Reset"
"resetAction": {
"mode": "initial",
"confirm": false,
"payload": {}
"saveDefault": {
"icon": "save",
"text": "Save Default"
"elements": [
"id": "Line",
"labelWidth": 10,
"options": [
"id": "10",
"label": "10",
"type": "string",
"value": "10"
"id": "11",
"label": "11",
"type": "string",
"value": "11"
"id": "12",
"label": "12",
"type": "string",
"value": "12"
"id": "_",
"label": "",
"type": "string",
"value": ""
"optionsSource": "Custom",
"section": "",
"title": "Line",
"tooltip": "",
"type": "select",
"uid": "04570bb6-642b-4e00-aba2-45cc9235674a",
"unit": "",
"value": []
"id": "Start",
"isUseLocalTime": false,
"labelWidth": 10,
"section": "",
"title": "Start",
"tooltip": "",
"type": "datetime",
"uid": "9a3ef965-bb71-4d6d-8f7b-69100a2bed0e",
"unit": "",
"value": ""
"id": "End",
"labelWidth": 10,
"section": "",
"title": "End",
"tooltip": "",
"type": "datetime",
"uid": "77cc154c-1dc2-46e4-a7de-ed0a36a91dcc",
"unit": "",
"value": ""
"id": "Planification",
"labelWidth": 10,
"options": [
"id": "0",
"label": "0",
"type": "number",
"value": 0
"id": "1",
"label": "1",
"type": "number",
"value": 1
"section": "",
"title": "Planification",
"tooltip": "",
"type": "multiselect",
"uid": "1bb83d12-d2ea-46cd-a1d7-793879b579cd",
"unit": "",
"value": []
"id": "id",
"labelWidth": 10,
"section": "",
"title": "id",
"tooltip": "",
"type": "number",
"uid": "c5db338f-0396-4b2a-93e7-a3727a80cfcd",
"unit": "",
"value": 0
"pluginVersion": "4.1.0",
"targets": [
"datasource": {
"format": "table",
"rawQuery": true,
"rawSql": "SELECT * \r\nFROM \"DATA_SCHEMA\".\"LINE\";\r\n---//VALUES ('$(payload.id)','$(payload.Ligne)', '$(payload.Start)', '$(payload.End)', '$(payload.planification)');\r\n",
"refId": "A",
"sql": {
"columns": [
"parameters": [],
"type": "function"
"groupBy": [
"property": {
"type": "string"
"type": "groupBy"
"limit": 50
"title": "test 3",
"type": "volkovlabs-form-panel"
I set value by hand, but nothing is write by grafana in my database
I tryied to follow this but I don’t understand how to achieve what I want, and they don’t explain how to just write a simple row in a database which would be a good start for a tutorial
