Update Request payload issue in Business Form Panel
In the query section of the Update request payload i have added a query.
INSERT INTO customer(customername, customercity, customerdescription) VALUES (
‘${payload.customername}’,
‘$cities’,
‘${payload.customerdescription}’);
when one of the fields(eg: customerdescription) are empty and when i click submit ‘${payload.customerdescription}’ goes into the database as it is.
  customerdescription
 tt
Is there a different way to add the query or is my syntax wrong?
@amaljoseph109 Do you use custom code with validation to prepare payload?
If you do, then remove if statement, which prevent adding it to the payload.
Thanks a lot :innocent:. This condition was there in the custom code
if (!element.value) {
    return;
I removed it and now its working fine.
