Dashboard Variable Debugger Feature
When the variable definition works, the values are displayed at the bottom. That’s great. When the definition doesn’t work, there’s some sort of errors/warnings fade in/out after some time. However, I think it’d be helpful to
  1. Persist the errors/warnings, hide/display it for review.
  2. Have some of debugger to see what’s not working. Something like Query Inspector is good.
Hi there,
That’s an interesting idea. Have you considered making an issue request in the grafana/grafana repo?
Hi Matt,
Thanks for your suggestion. I’ve opened an issue in the grafana repo for tracking this feature request.
John Lee
