Greetings!
Is there is a way to copy the panel from the “Comparison” tab of Drilldown to a another dashboard?
Currently, Grafana does not allow you to directly copy a panel from the “Comparison” tab of the Trace Drilldown (like in Tempo or exemplars) into a standalone dashboard panel.
Workaround Options:
- Recreate Manually
Use TraceQL (if using Tempo) or Loki logs/metrics to replicate a similar comparison manually in a dashboard. - Snapshot the UI View:
You can take a snapshot (Share → Snapshot) of the Comparison tab and embed it in dashboards as an image
