Enhancement request - panel duplicate and panel move function
I’m new to Grafana and while experimenting I’ve found that I’ve wanted to experiment with changes before releasing them on a production panel. It would be really hand to have the possibility to duplicate a panel, so you can make changes to the new one and not break the working one, and also a move panel function to allow you to move a panel to another dashboard - such as your experimental panel where you play around with settings.
I’ve found I’ve had to do quite a lot of opening two windows, copying settings from a working panel to a new one to then modify the copy.
You can duplicate panels. This have been supported for a long time. Click up the context menu for a panel, select More and then duplicate.
Regarding moving panels we’ve introduced a new feature that will be included in Grafana v5.0, right now only released in beta. See issue.
Marcus
In fact I have the beta version running, I just hadn’t tried that more menu option and didn’t know what the panel option even meant.
Thanks
Hi @anon34853223, I use Grafana 7.3.6 and could not able to copy and paste Panels. Each panel has more than 30 graphs and create a new panel will be so hard. Do you have any solution for me?
Hi @nildenist
Are you trying to copy panels across dashboards?
To duplicate a panel you can use the following menu
At the top, theres a dropdown next to the Panel Title. You should see a “More…” option. In that submenu, the ability to duplicate a panel is there
Hi @TaiyoShin actually I mean row panel. After creating panels under row panel, I want to duplicate this row panel. How can I do this on Grafana?
@nildenist I could not find a way to copy paste or duplicate rows in a fashionable way.
What you can do is:
1.Go to Dashboard Settings
2.Select Json Model
3.Find the appropriate panel of type “row” like the following example:
      "title": "Teste1",
      "type": "row"
4.Copy the value and paste it/duplicate this value and you will get another row.
I followed this steps and was able to duplicate a row. Just keep in mind that, even though I didn’t mention in the steps, the final model must still be a Json.
@TaiyoShin what did you mean by “paste it”? Could you share an example?
Yes I can show an example.
As you can see in the picture above, I have a panel inside a row.
The Json in the json-model is:
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": "-- Grafana --",
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "editable": true,
  "fiscalYearStartMonth": 0,
  "graphTooltip": 0,
  "id": 3,
  "links": [],
  "liveNow": false,
  "panels": [
      "collapsed": true,
      "gridPos": {
        "h": 1,
        "w": 24,
        "x": 0,
        "y": 0
      "id": 4,
      "panels": [
          "fieldConfig": {
            "defaults": {
              "color": {
                "mode": "palette-classic"
              "custom": {
                "axisLabel": "",
                "axisPlacement": "auto",
                "barAlignment": 0,
                "drawStyle": "line",
                "fillOpacity": 0,
                "gradientMode": "none",
                "hideFrom": {
                  "legend": false,
                  "tooltip": false,
                  "viz": false
                "lineInterpolation": "linear",
                "lineWidth": 1,
                "pointSize": 5,
                "scaleDistribution": {
                  "type": "linear"
                "showPoints": "auto",
                "spanNulls": false,
                "stacking": {
                  "group": "A",
                  "mode": "none"
                "thresholdsStyle": {
                  "mode": "off"
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
                    "color": "red",
                    "value": 80
            "overrides": []
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 0,
            "y": 1
          "id": 2,
          "options": {
            "legend": {
              "calcs": [],
              "displayMode": "list",
              "placement": "bottom"
            "tooltip": {
              "mode": "single"
          "title": "Panel Title",
          "type": "timeseries"
      "title": "Teste1",
      "type": "row"
      "collapsed": true,
      "gridPos": {
        "h": 1,
        "w": 24,
        "x": 0,
        "y": 0
      "id": 4,
      "panels": [
          "fieldConfig": {
            "defaults": {
              "color": {
              "custom": {
                "axisLabel": "",
                "barAlignment": 0,
                "fillOpacity": 0,
                "hideFrom": {
                  "legend": false,
                  "tooltip": false,
                  "viz": false
                "lineWidth": 1,
                "pointSize": 5,
                  "type": "linear"
                "spanNulls": false,
                "stacking": {
                  "group": "A",
                  "mode": "none"
                  "mode": "off"
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
                    "color": "red",
                    "value": 80
            "overrides": []
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 0,
            "y": 1
          "id": 2,
          "options": {
            "legend": {
              "calcs": [],
            "tooltip": {
              "mode": "single"
      "title": "Teste2",
      "type": "row"
  "schemaVersion": 34,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": []
  "time": {
    "from": "now-6h",
    "to": "now"
  "timepicker": {},
  "timezone": "",
  "title": "New dashboard",
  "uid": "WT5TwP-nk",
  "version": 3,
  "weekStart": ""
To create a new row with a copy of the panels in the row i can copy the relevant part and add it to the model as follow:
  "annotations": {
    "list": [
        "builtIn": 1,
        "enable": true,
        "hide": true,
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "editable": true,
  "graphTooltip": 0,
  "id": 3,
  "links": [],
  "liveNow": false,
  "panels": [
      "collapsed": true,
      "gridPos": {
        "h": 1,
        "w": 24,
        "x": 0,
        "y": 0
      "id": 4,
      "panels": [
          "fieldConfig": {
            "defaults": {
              "color": {
              "custom": {
                "axisLabel": "",
                "barAlignment": 0,
                "fillOpacity": 0,
                "hideFrom": {
                  "legend": false,
                  "tooltip": false,
                  "viz": false
                "lineWidth": 1,
                "pointSize": 5,
                  "type": "linear"
                "spanNulls": false,
                "stacking": {
                  "group": "A",
                  "mode": "none"
                  "mode": "off"
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
                    "color": "red",
                    "value": 80
            "overrides": []
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 0,
            "y": 1
          "id": 2,
          "options": {
            "legend": {
              "calcs": [],
            "tooltip": {
              "mode": "single"
      "title": "Teste1",
      "type": "row"
      "collapsed": true,
      "gridPos": {
        "h": 1,
        "w": 24,
        "x": 0,
        "y": 0
      "id": 4,
      "panels": [
          "fieldConfig": {
            "defaults": {
              "color": {
              "custom": {
                "axisLabel": "",
                "barAlignment": 0,
                "fillOpacity": 0,
                "hideFrom": {
                  "legend": false,
                  "tooltip": false,
                  "viz": false
                "lineWidth": 1,
                "pointSize": 5,
                  "type": "linear"
                "spanNulls": false,
                "stacking": {
                  "group": "A",
                  "mode": "none"
                  "mode": "off"
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
                    "color": "red",
                    "value": 80
            "overrides": []
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 0,
            "y": 1
          "id": 2,
          "options": {
            "legend": {
              "calcs": [],
            "tooltip": {
              "mode": "single"
      "title": "Teste2",
      "type": "row"
  "style": "dark",
  "tags": [],
  "templating": {
    "list": []
  "time": {
    "from": "now-6h",
    "to": "now"
  "timepicker": {},
  "timezone": "",
  "uid": "WT5TwP-nk",
  "version": 3,
  "weekStart": ""
Note that what was added was a panel of type row. It’s not elegant but it worked for me
Hi @TaiyoShin
The solution you offer have questionable issue:
Where this json should be pasted? I want to duplicate row panels in the same dasboard, and a dashboard has only one json model. I try to paste row panel jason part into dashboard’s json model but it doesn’t save.
And could you share the duplicated row panel’s ss? Thanks.
I have tested and got results with the above method.
Yes, the dashboard does have 1 model only but overwriting the Json model should work. Thats how i got the duplicate part.
I don’t understand what you mean about ss and I cannot tell which panels you want to duplicate.
This is the duplicate part on the example i sent
      "collapsed": true,
      "gridPos": {
        "h": 1,
        "w": 24,
        "x": 0,
        "y": 0
      "id": 4,
      "panels": [
          "fieldConfig": {
            "defaults": {
              "color": {
              "custom": {
                "axisLabel": "",
                "barAlignment": 0,
                "fillOpacity": 0,
                "hideFrom": {
                  "legend": false,
                  "tooltip": false,
                  "viz": false
                "lineWidth": 1,
                "pointSize": 5,
                  "type": "linear"
                "spanNulls": false,
                "stacking": {
                  "group": "A",
                  "mode": "none"
                  "mode": "off"
              "mappings": [],
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
                    "color": "red",
                    "value": 80
            "overrides": []
          "gridPos": {
            "h": 9,
            "w": 12,
            "x": 0,
            "y": 1
          "id": 2,
          "options": {
            "legend": {
              "calcs": [],
            "tooltip": {
              "mode": "single"
      "title": "Teste2",
      "type": "row"
Its a copy of Teste1 but changed the title to Teste2
