Duplicated Panel Settings Issue
Version – Grafana v11.3.0
I am using a scatter plot panel to show run charts / control charts for production data. For the whole dashboard this results in 6 to 10 panels which I want to have the same view, but need different mins / maxes due to the measurement values differing by requirement.
To speed things up I have tried to duplicate a panel, tweak the query to a new parameter, and then update the standard options (min / max) that are appropriate for that requirement. I am updating the standard options in a field override for a specific series.
My issue – when updating the standard options on a duplicated panel, it also updates the standard options on the original panel. Same issue happens when updating the original panel (duplicated panel settings update as well).
Is there a reason these settings are tied to each other? Any way to copy a panel without linking the settings in this way?
Thanks,
Mike
