I’m having trouble getting a docker-compose/nginx reverse proxy app going. Here’s the setup:
docker-compose.yaml
version: '3'
services:
webserver1:
image: nginx
ports:
- '8080:80'
volumes:
- ./html:/usr/share/nginx/html
- ./nginx/nginx.conf:/etc/nginx/nginx.conf
grafana:
image: grafana/grafana-enterprise
container_name: grafana
environment:
- GF_SERVER_DOMAIN=https://localhost/grafana/
- GF_SERVER_ROOT_URL=https://localhost/grafana/
restart: unless-stopped
ports:
- '3000:3000'
volumes:
- ./grafana/custom.ini:/etc/grafana/custom.ini
nginx.conf
# This is required to proxy Grafana Live WebSocket connections.
events{
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream grafana {
server localhost:3000;
server {
listen 80;
#root /usr/share/nginx/html;
#index index.html index.htm;
location / {
proxy_set_header Host $host;
proxy_pass http://grafana;
# Proxy Grafana Live WebSocket connections.
location /api/live/ {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
custom.ini
[server]
protocol = http
http_addr = localhost
http_port = 3000
domain = localhost
root_url = %(protocol)s://%(http_addr)s:%(http_port)s/
Also, when I curl to 8080, I get a 502 error. I get the following error message in the docker compose logs:
webserver1_1 | /docker-entrypoint.sh: Launching /docker-entrypoint.d/20-envsubst-on-templates.sh
webserver1_1 | /docker-entrypoint.sh: Launching /docker-entrypoint.d/30-tune-worker-processes.sh
webserver1_1 | /docker-entrypoint.sh: Configuration complete; ready for start up
webserver1_1 | 2025/08/14 02:25:11 [error] 29#29: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.22.0.1, server: , request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:3000/", host: "localhost:8080"
Please advise.
