Hello eveyone!
I am having some problems when using reverse proxy. It always response Unable to connect when I access from browser.
Error.log File:
connect() failed (111 connection refused) while connecting to upstream client
I need help to fix this issue.
BR.
ahmedmouawad453:
gov.sa
I’m guessing this government URL might have something to do with your troubles.
All, here is a good troubleshooting guide for NGINX:
Did you configure Grafana to run on port 8080? The default is 3000, so if your Grafana is running on the default settings the proxy line should read:
proxy_pass http://grafana.staged-by-discourse.com/
You have nginx listening to port 3000 - normal SSL listens at 443 - so not sure if you got confused on the ports, or that’s something unique to your service/gov etc.
whatever port you have Grafana served on, do a curl request to validate it’s working. Then move on to fixing nginx.
Thanks @anon70503803 . I need to edit my topic but I can’t do this. Please advise.
hmmm, that’s strange. Maybe just add a new response to the thread with any news or updates
Hi @anon70503803 I need to remove this topic please any support?
Thanks
