Error 403 with NGINX
Hi all,
I am sorry for the 100th topic regarding this, but I haven’t found the solution so far.
What?
I can access the page without problem with http://my_server_ip:3000 but https://grafana.my_domain.com just returns error 403.
Symptoms?
I run Grafana as a docker on my local server and use nginx (swag docker) as reverse proxy.
Each time I try to access grafana through the reverse proxy I get an error 403 but don’t see any hinting log to see what is wrong. The grafana server is running in a docker container named grafana. The ssl handling works as other services have no problem with it. I also added the proxy_set_header Host $http_host; line as I saw it created problems but it didn’t solve it.
Anyone can see what is the problem in the nginx configuration?
Nginx proxy-conf:
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name grafana.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    location / {
        include /config/nginx/proxy.conf;
        include /config/nginx/resolver.conf;
        set $upstream_app grafana;
        set $upstream_port 3000;
        set $upstream_proto http;
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
    location ~ (/grafana)?/api {
    location ~ (/grafana)?/metrics {
try to put
set $upstream_app grafana; using your IP
set $upstream_app 192.168.1.100; for example.
Regards,
Fadjar
THe IP isn’t the problem as the container can find it (it is handled by docker network).
If nginx couldn’t reach the grafana container I would get a log entry saying it can’t find it, plus if I ping fron nginx to grafana (using name not IP) it responds. So I don’t think the problem comes from that.
Is there any firewall running to block port 3000 at the target?
No firewall, I use the official grafana image (Docker).
I can access grafana locally with grafana:3000, only grafana.mydns.com doesn’t work so it seems to be something fishy in the nginx configuration.
I hope you got through this setup?
Based on the provided configuration, the issue may also related to the server_name directive. It is set to grafana.* , which will match any subdomain of the grafana domain, but not the grafana domain itself. To fix this, you should change grafana.* to grafana.my_domain.com.
The HTTP 403 Forbidden response status code indicates that the server understands the request but refuses to authorize it. In case of FW or any other unavailability I would expect a 5xx code.
I will run through the link make sure everything is fine. Be right back. Thanks @jiriwetter for the link.
Hi again @jiriwetter
Unfortunately the example doesn’t fix it. If I copy the given example it redirects to index.html (as I suppose it can’t find grafana on the localhost as it is running in a different container). If I replace localhost by grafana (as that is the IP of the container) then I still get the error 403.
Are there any logs I can check to find more hints of what goes wrong between nginx and grafana?
I can’t see any entry in the grafana containers and the nginx log is also not helping much.
The only things I see are in nginx logs, I can see the access at 07:21:15:
138.199.xx.xx - - [03/May/2023:07:21:15 +0200] "GET / HTTP/2.0" 403 146 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/112.0"
But nothing in error.log:
2023/05/03 07:18:04 [alert] 527#527: [lua] init_by_lua:8: [Crowdsec] Initialisation done
Please try to disable Crowdsec first, I think there’s a problem with Crowsec lua scripts.
For testing better using vanilla nginx without mod_sec or other modules, such as resty or Crowdsec.
If the nginx vanilla distribution works, add one by one the hardening scripts…
Regards,
Fadjar
Hi @kodsama,
there are a lot of places to make mistakes. I did the same thing you’re trying to do. So I have a proxy server where I have SSL termination that redirects all requests to the docker host where the Grafana container is running.
Internet > proxy server > docker host > container
I’m using this simplest possible configuration so that nothing else confuses you.
server {
listen 80;
server_name grafana.xx.cz;
return 301 https://grafana.xx.cz$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl on;
ssl_certificate /etc/letsencrypt/live/grafana.xx.cz/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/grafana.xx.cz/privkey.pem;
index index.html;
location / {
proxy_pass http://10.52.4.14:3000/;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto "https";
$ curl -sk -IL https://grafana.xx.cz
HTTP/2 302
server: nginx/1.18.0
date: Wed, 03 May 2023 06:51:39 GMT
content-type: text/html; charset=utf-8
cache-control: no-cache
expires: -1
pragma: no-cache
set-cookie: redirect_to=%2F; Path=/; HttpOnly; SameSite=Lax
x-content-type-options: nosniff
x-frame-options: deny
x-xss-protection: 1; mode=block
HTTP/2 200
content-type: text/html; charset=UTF-8
expires: -1
pragma: no-cache
I think you have a mistake on the nginx side. But it’s very hard to advise when we don’t know what other settings you are using besides nginx - maybe on the OS side. Anyway, the higher logging level is described here:
http://nginx.org/en/docs/debugging_log.html
Yes, it works now!
There was something fishy which was part of the
line of the default grafana nginx config. Commenting it out and adding the extra parameters like you had fixed it :slight_smile:
Thanks for the great support!
