Nginx Reverse Proxy
I am trying to setup Grafana with an Nginx Reverse Proxy for SSL Termination.
Grafana: v6.2.5
I have attached some relevant configs for this:
grafana.ini
[server]
domain = grafana.example.com
nginx.conf
listen 443 ssl;
server_name grafana.example.com;
location / {
  proxy_pass http://127.0.0.1:3000;
Every other config in grafana.ini is left to the default.
I can access the login page fine if I connect directly to Port 3000. However, attempting to access via the domain name brings up the error regarding reverse proxy configuration issues.
I can access the API with the domain name:
$ curl https://admin:admin@grafana.example.com/api/org
{"id":1,"name":"Main Org.","address":{"address1":"","address2":"","city":"","zipCode":"","state":"","country":""}}
I have also attempted to change the root_url and it did not work. Port 3000 worked but using the Domain brings me to the same error page for /login .
Initially, this was setup in a Docker Compose with Nginx running on host but I moved Grafana out of it to try to make it easier to debug.
The server it is on is also hosting a Prometheus in Docker with reverse proxy.
Hi Arvent,
According to the documentation, in the Nginx you should have the following configuration:
listen 443 ssl;
location / {
  proxy_pass http://127.0.0.1:3000/;
After some additional testing, I discovered that certain calls are being blocked by my Nginx’s Security Headers/Settings.
I discovered these errors in my Browser Console when loading the login page:
EvalError: call to eval() blocked by CSP core.js:4
Content Security Policy: The page’s settings blocked the loading of a resource at eval (“default-src”). angular.js:1286
Content Security Policy: The page’s settings blocked the loading of a resource at eval (“default-src”). core.js:4
I use the following security headers by default in my Nginx installations:
# security headers
add_header X-Frame-Options "SAMEORIGIN" always;
add_header X-XSS-Protection "1; mode=block" always;
add_header X-Content-Type-Options "nosniff" always;
add_header Referrer-Policy "no-referrer-when-downgrade" always;
add_header Content-Security-Policy "default-src 'self' http: https: data: blob: 'unsafe-inline'" always;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload" always;
# . files
location ~ /\.(?!well-known) {
  deny all;
After commenting out the Content-Security-Policy Header, Grafana works as expected on a Reverse Proxy.
It seems that the frontend may be performing some unsafe eval calls?
