So i am having issue with grafana and reverse proxy (nginx)
Its giving Error 521 Webserver is down on cloudflare domain
My Nginx.conf is
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
# include /etc/nginx/conf.d/*.conf;
server {
listen 443 ssl;
server_name www.mydomain.net;
# access_log logs/file.acees.log main;
ssl_certificate /etc/nginx/certs/domain.net.pem;
ssl_certificate_key /etc/nginx/certs/domain.net.key;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $host;
proxy_set_header X-Url-Scheme $scheme;
proxy_redirect off;
proxy_max_temp_file_size 0;
location / {
add_header Content-Security-Policy "script-src: 'unsafe-eval' 'unsafe-inline';";
proxy_pass http://<ip>:3000/;
My Grafana.ini is
;protocol = http
;http_addr =
# The http port to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
;domain = www.mydomain.net
;enforce_domain = false
;root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
;serve_from_sub_path = false
The grafana login page is accessible throught ip:3000 but the domain gives nothing but an error 521.
Any help will be much appreciated
