Hey. What Grafana version are you using? This may be an issue with encryption. Try and change your username in Grafana from <existing username> to <existing username>; encrypt=disable
This is a setting that you can configure in datasource settings in Grafana starting from version 5.4.0, see issue for details.
I have grafana 5.2.4. Where I have to write <existing username>; encrypt=disable ? On the custom.ini after ###### database ###### ?
I’m changing from a MySQL server and it was working without any problem.
I don’t know what goes wrong here. I configured a rule on my firewall for the port 1433 too but nothing…
Yep I’m on the same machine. I started by using SQL Server 2017 devellopment as it wasn’t working, I started to use SQL Server 2017 Express. I installed both of them.
