zirain
April 23, 2018, 5:27am
1
Hi guys:
I’m running grafana v5.1 on win10 WSL ubuntu, then always get an error like ‘Login error: EOF’ when trying to save&test a mssql datasource, any suggestions?
if change the host to an unexists ip,there will be an error like ’
Unable to open tcp connection with host ‘localhost:1433’: dial tcp 127.0.0.1:1433: connect: connection refused’
thx!
First, check the Grafana server log after you’ve received your connection error.
Second, are you possibly trying to connect to a MSSQL 2008/2008 R2 version? (show result of select @@Version)
From the GO library we’re using in Grafana to connect to MSSQL:
SQL Server 2008 and 2008 R2 engine cannot handle login records when SSL encryption is not disabled. To fix SQL Server 2008 R2 issue, install SQL Server 2008 R2 Service Pack 2. To fix SQL Server 2008 issue, install Microsoft SQL Server 2008 Service Pack 3 and Cumulative update package 3 for SQL Server 2008 SP3. More information: KB2653857 - FIX: You cannot connect to SQL Server by using JDBC Driver for SQL Server after you upgrade to JRE 6 update 29 or a later version - Microsoft Support
If upgrading is not an option for you I suggest you to create a feature request issue for possibility to disable encryption, see Login Error:EOF or An existing connection was forcibly closed by the remote host · Issue #42 · denisenkom/go-mssqldb · GitHub .
Marcus
zirain
April 23, 2018, 11:13am
3
Hi,mefraimsson
thx for your reply, my SQL Server is 2008 R2, I’ll try as you told
Cool. I’ll update the documentation regarding 2008 (R2).
I created an issue for it to start with.
Documentation have been updated with known issues section.
zirain
April 28, 2018, 1:52am
7
@anon34853223 ,thanks for the updated!
@anon34853223
after upgrade to v5.1.3
still get an error like “wsarecv: An existing connection was forcibly closed by the remote host.”
Is this a Known Issue?
But have you upgraded your sql server 2008 r2 to latest service pack?
zirain
June 4, 2018, 10:59am
10
not yet, there’s not a plan to upgrade product database,any other solution?
Hi, I am using MSSQL 2012, and have same error. What can I do?
