Clarification regarding multi select custom variable in grafana
Hi ,
I am new to Grafana …
Need one clarification.
I have a custom variable with multi select enabled.
Now , I want to store the second value of the multi select variable in another custom variable and use it internally .
How to achieve that in grafana.
Please let me know.
Thanks,
Nilanjan
What do you mean by the second value? AFAIK when you select multiple values, you have to use them all. What do you need it for? Maybe we could come up with something other?
What is your datasource for the custom second variable?
What makes the second value the second value?
Is the second value always static or dynamic?
