11.2.0 -
Creating a custom variable called “StoreId2”; Call other custom variable by using ${var:csv} -
What happened?
I expect sca_d1 and sca_d2 can be two option be selected in variable StoreId2; when select one of variable, multiple -
Configuration show in picture. -
No -
