Latest 11 -
View HTML content as HTML without sanitizing. -
Set in grafana.ini:
[panels]
disable_sanitize_html = true
Restart:
sudo systemctl restart grafana-server
What happened?
The HTML is still sanitized. -
View the html/text content. -
Yes:
Configure Grafana | Grafana documentation
Do I able view the content of the table cell in HTML format and not sanitize it?
